LuPo_81
Sorry, I use wf 4.0.
As for the series I don't know how to give you precise indications as I didn't understand how it works. I also encountered problems with the series when I manage the surfaces, I often solve by doing the series in the axieme.
cmq I went to attempts and placed the result, although it seems to me that 3 blades are different from the first. Maybe it's better to be a witness.
That's how I did it.
-I moved the feature axis before the others, after the reference plans
-I have grouped the features of the creation of ciscous, points, splines, cylinders, projections and trims (excluding the parallel blend)
- I created a series of this group
-I created a series of parallel blend (using the reference series)
- I joined the surfaces of one shovel
-I solidified the only shovel with the surfaces united
- I repeated the two previous steps for each shovel
Try making the series you need and see a little, maybe you can do better than me.
