creazione different
  • Thread starter Thread starter Fabrizio69
Fabrizio69
First of all, hello to all,
I'd have a little swallow I can't get through.
I have a set of blocks with relative attributes, I can't find and/or change an lsp that does to my case. design, with blocks with attributes, modular structures. I was looking for a command that made me apart from the individual attributes properties, even the sum per block.
example, each block has a cost and a weight, I wanted that in the resulting table you would see the sum of weights and cost, always obviously divided by "block name "
I found something here on the forum, but:(I can't track it anymore.
You could try with extra data tools, exposing everything on excel, where you will run the sums.
Steps are: tools>you will extract data>save the file>create data extraction»advanced blocks affecting you>down the attribute filter»and then choose which attributes you want to see>open a preview, where you can order the table as it is most useful>advancedoutput of data on external file>select the percrso>fine
once you do this apply the formulas you need, all without lsp. the advantage is that the file will be updated if you add changes to the attributes. .
with extra data is definitely done, but as process requires some passage. if you could do with a lsp the creation of the table would require only one command. I believe the sum job can be done directly by attributes, but also on this process I do not have much clear ideas if not long and windy procedures.
