creo distributed batch 11.0.0.0 - export problems
  • Thread starter Thread starter Daniele-san
Daniele-san
Good morning.
I wonder if you have noticed export problems with creo distributed batch 11.0.0.0.
once I started the groups with the settings set (using the same .dxc file I created since I started using this tool) does not end the export some files remain in the "operative" status some "not delivered" (no one in the "unfinished" and/or "unsuccessful" status) status and in the directory assigned for export there are no files.
yesterday came out on 11.0.1.0, you can try with that if you can't understand in other ways
I tried to make two identical batch exports (drw -> dwg) from creo 10 and creo 11, set from zero, worked in both cases.
made a test at the pdf exporting flight of a couple of tables and it works me creo11. possibly you could check if there is a distributed batch restriction in windows security settings.
non credo may dipendere da questo
Are current export logs created? (e.g. dwg_2d_export_ttd.log.1)
I would also look at the creo trail, if it is executed.
look even if you find std.out that can show any problems.
Hi nicksoft,
Maybe I solved after multiple tests... apparently there is a string of the config.pro that does not allow dbatch to continue in operations, probably in version 11 (compared to 10) has changed something and while not changing the config there is some string that does not digest... .
Now I have to understand which of the many....
I should have solved... .
the problem is inherent in the config. pro that with the new version, I create 11 previews the move of the macros in the file mapkey.pro for which in the config should be deleted
apparently they affect the good functioning of dbatch
too strong resolution
