Etruria89
Hello everyone,
are struggling with the calculation of critical load on a marine engine propeller tree; the system I schematized for the careful calculation of the critical load on this tree appears as:
beams having as a section that of less resistance of the entire tree (i.e. a tubular section), bound to an estermum with a hinge (conical roller shutter on which the propeller is discharged), in the central section with a support (ball clamp) and with the other free exterminity (where the propeller is present and therefore the resulting load from it).
to study the system I have exploited both the equations of the elastic line and the energy method in such case exploiting as functions of form a double sinusoid deformed in the tract between the two bearings and a linear deformed in the tract between the central support and the free estermo, however the problem is that for the so set problem I always obtain as a result as root of the problem to the autovalues a accept nothing and other two high minds.
you would know how to justify the presence of this root nothing if the problem was correctly set.
