crop an imported image in solid edge
la.laura
good evening, I imported a solid edge image and now I should cut it by following a particular profile (i.e. it is not enough to make it bigger or smaller, but I have to cut it by giving it a different shape from its - which is currently rectangular), is there a way?
Where did you import the image?
prepares the image on an image editor program. the background, which you will want transparent, color of a unique color (white or fuchsia). in solidedge, once you insert the image, in its properties you find like "use this color as a transparent background".
always there you find "show edges" (it puts the rectangle as lines).
after you have scaled and positioned (with move) the image, use the relationship blocks.
Since you've done similar posts, maybe you don't need this solution, maybe it will be useful to others.
Bye.
