ctb file path
  • Thread starter Thread starter Luigi1
Luigi1
Help!
I can no longer apply ctb print styles.
from the style editor I can see the path of ctb files, but that path does not exist on my pc. However autocad(2010) says that the file is existing.
even if I create a new style, autocad saves me in this folder that does not exist. . .
how does autocad create and save a file in a card that does not exist? ? ?
Has anyone ever happened anything like that? Am I stupid?
Is there a way to choose the folder where autocad saves ctb after creating them?
Otherwise, I'm afraid I'm getting stuck.
in autocad file menu choose "plot style manager" (I believe it is management sti print in Italian). open the folder where ctb reside
or keyboard _stylesmanager
you may not see the path because one of the path folders is withdrew, and this is normally hidden as a folder
Big crystal! Thank you! You are all in your place indeed.
Then why doesn't autocad apply my styles? ? ?
but what does it mean doesn't apply styles?
Can you see only stb file? if yes, use _convertpstyles keyboard or _convertctb
I never used a stb file...
simply when I send in print and "print with print styles" the style I choose is not applied. takes the attributes from the layers.(until a month ago it worked properly.
