curiosities on file sldasm
  • Thread starter Thread starter stefanobruno
stefanobruno
work with inventor for a customer who has always used sw and now also has inventor.
They tell me they'd like the model of welds, which with inv. consists of a .iam file plus n .ipt files of semi-finished, in a single file, as it does sw.
I fell from the pear, inventor generates .ipt files derived from a .iam file, but loses all parametric info.
really sw contains the parametric information of a welded in a single file?
Thanks, bye.
Yes. is called multibody modeling.
in a single file the welded bodies are managed and it can be given to each body to give properties and also to assign different material having a distinct production materials (which solid calls distinct cutting to differentiate it from that of axiemi).
these bodies can also be saved as single files always keeping the adactivity with the original file; It is a comfortable thing if, for example, a welded and processed part, prepare the bodies individually before welding. model the welded worked and finished, extrapolate the individual bodies and add them of the overmetal or cyanphrines for welding for example.
you can obviously add welds and using dedicated functions automatically make the recesses between the various profiles and other things.
I saw here "
" that the multibody also makes it inventor, but to say that everything is enclosed in a file, it seems incorrect.
The model you mean is like that of the film or is it more evolved?
