current density
  • Thread starter Thread starter kekko750
kekko750
Hello everyone, I am a studend graduating in electrical engineering and because of the thesis I found myself using ansys 10, being that I have to find the current density on a massive conductor, I would plot such greatness, but when I type the command plnsol,jc, it gives me error. I hope you can help me
I made a simple thread with a current... it seems to me to work.
the command is not the one you used but: plnsol, jc,z, 0
Hello I have just made the change, but as he did before tells me jc item in invalid
I attach the list of the commands of my project, knowing that with your help you can make the necessary changes in order to plot the jc and maybe build a graph of the current density, excuse me and thank you in advance for the help you can give me
check the outputs of solid97 ..see attachment ...
jc is not expected ..
Now I will try to change the list of commands with your advice, another question, if I want to see the skin effect along the massive conductor, what do you sow me to do?
First of all it contriolla that the mesh is sufficiently defined.
There is a formula (which I remember more) to estimate the depth of the skin effect.
make sure that in that thickness there are 2-3 elements at least.
Hello I think I solved the problems, since it had a higher penetration depth than the thickness of the piece did not show me anything, so I increased the frequency, do you have any other advice? or did I do well to increase the frequency to see some skin effect?
