curve on imported points.
  • Thread starter Thread starter vale61
vale61
hello to everyone, I've finally been hired in a new company after more than a year of "increasing".
I imported into the sketch (from excel) the points I need to make a curve, now I have all points (about 200) in the sketch, select references - curve and the only way I managed to find is to join one point after another.
It's not a job that takes away a lot (3-5 minutes) but...
... is it possible to track the curve that passes for all points automatically? or maybe selecting only the first and last point?
if the points are selectable as feature in the template tree should be tracked with only one click ... well back and wishes for the new job.
Excuse me, it doesn't work the same way.
on the reference points created as feature there are no problems.
If the points are an import feature, it does not make me the curve by selecting with just one click all points.
If I think of something, I'll let you know.
Hi, I'm sorry if I interfere.
If the points amounts them from an excel format you can use the point-> offset coordinate system command and, in this case finding you a single feature, you can make a single selection for the 3d curve.
Sorry I'm late. I couldn't connect earlier.
maxopus in fact are not in the model tree.
I'm trying to see how you recommend it tomorrow.
That's right.
bphausto, they were imported as you say, and in fact on the tree there is only one feature that identifies all points.
But when I go to the curve and try to insert the feature, it's like it's just taking one point, so it doesn't create the curve.
That's right.
Hi, vale,
try to select the feature point from the model tree and not from the window and then generate the curve, it should work.
Hi, vale,
I also tried so but nothing, it seems precisely that the feature point (which really are all points imported) considers it only one point and expects therefore to continue to select others.
Hi, vale,
try to break down the number of points in lower number groups should make it.
