peloritano
Hello everyone.. .
I was messing around a little bit with a cat and the following happened to me:
after drawing a simple rectangular section beam I had to make a hole and the rounded bevel of a corner so I chose a beam wall and entered the sketch function (see attachment).
to solve a problem of overpass I started to put hand in the various drop-down menus that opened when I was right-clicking first on the constraints and then on the geometry.
At one point my geometry, that is my bevel, is represented by a thicker line. However I conclude operations on my sketch and I go out from the same.. .
the result is that the highlighted geometry is brought out of the sketch and those that were my intentions were not performed (see attachment).
How do you activate this option?? ?
How do you turn off? ?
What do you think might be useful? ?
ok I found that by right-clicking on geometry and choosing the emission feature option is highlighted.. the other two questions remain
How do I get back? ?
What could that serve?
