BCgeppoIT
Good morning to all, I often find myself using the edit polylinea command, I wanted to ask if you can create a custom command to avoid all the steps that autocad of practice asks, my command is always used in this sequence:
-edit polylinea
- select an object
- to the question "you want to turn it into polylinea" the answer is always
-to the request "type an option" the answer is always combined so that the polyline is completely closed.
I hope I explained.
hello good day
-edit polylinea
- select an object
I hope I explained.
hello good day
