custom file fall
  • Thread starter Thread starter Roberta Cappelletti
Roberta Cappelletti
Good morning.
I am new to this forum and I would need a hand. I've been using autocad for many years now and I've never had anything like that. by mistake I changed the interface settings of the program. now the screen turns out empty. I no longer have any command in sight, I only have the bar where to enter the text. I also saved my profile settings to avoid problems like this. if I try to reset my profile tells me that the file is not found even if I searched and set it manually. trying to solve the problem opened this autocad message "no main customization file has been defined: such file is necessary to add or change the customization content. to define one, at the command line type chargeiupers, or choose the card manage> group customizations> user interface in the All-In-One bar" obviously making chargeiupers do not arrive anywhere.
Does anyone have any idea what the hell happened? ? ?
Thank you for your help.
command menu, fence and richer acad.cuixto no longer have these problems let the profiles stand, migrate custom settings (export) so as to create a file to "import" them if necessary.
Thank you very much. I've been freaking out for a few days. !
I will certainly make an export as I recommend, it can come in handy! !
