GP.
if the syntax to use is:[NOMELIBRERIA(NOMESLIDE)]You must write:[idramidag(nere40x40)]... Everything was fine except the black screen...
non[pozzetto(nere70x70,Pozzetto 70x70)]if you don't have to distribute the menu, I suggest you don't use the slide library (.slb), but enter the name of the single slide, any change to the slide is displayed immediately without having to remake the library.[NOMESLIDE]the blocks to be inserted must be created with mlock (_wblock), it is not possible to insert those that you have attached as "they refer to themselves".
for the syntax of insertion from a look to the example of pippo.mns, are contemplated various assumptions that do different things, do tests.
