MassiVonWeizen
is the automatic creation of the cartiglio, but present from 2018 seems to meon google I found the function "automargin", I do not know if it is that, but in my version I do not find it on > edit sheet format
create a sheet size pane and quoti, then select the bottom left vertex and with the property manager the x0 and y 0 positions. Make it fixed and use it as a board. in the end if you want you can delete ithow can I quote from the edge of the sheet? so you can set the table well for printing?
