graziano-g
hi, excluding alignments/disposition views and lack of the inscription box in the attached image, I need to insert on the drawings of the individual sheet metal parts a table that brings it width, length, thickness and material.
starting from tables > separate materials with double click on the column number, as you know, you can choose what to connect to the cell below between the properties available.
starting from here:
Moreover it would be convenient to recall the table with a key or combination, with a macro, to that I am working on it.
Thank you, good Sunday.
starting from here:
- Table 1: starting after some tests (it is not the default configuration )
- Table 2: Hidden columns at + b (click dx on column + hide column and reduced row height with double click on the symbol that appears by approaching the cursor to the rows division line ). last second row cell appears material.
- table 3: hidden according to line.
- save the table by name (click dx on any point of the table then select the item )
- Table 4: again insert the saved table.
- recompil the middle row, without the material....
