customise keyboard commands
MARCOC
Good morning to all
in autocad, in the keyboard commands, example I type l, and to activate the command I have to press sending or space bar, I am to ask you and possible to encapsulate also the sending, i.e. typing the command directly asking me the first point.
is the way by modifying the .pgp file where the alis do what they asked? Do I have any other way?
Thank you very much
no non c'e' modo. and there must be no, otherwise acad who knows if you want to write only l (by line) or lu (by length)?
as soon as you press it would start a line, preclude all the commands that start for l.
then reformulate, we take the zoom extension command, z sending and sending, I'm sure that with lisp you could automate the command but it's too many years that I don't use autocad, once you created the lisp and possible to associate it with a button using the pgp file?? ?
Thank you very much
You don't need to shake the lisp, do whatever you want.
create a new key and put in it the macro you want, like "zoom"; "_e";
But if you want to do this... you already have the key!
by keyboard subscribe commands, type l=linea; ll=allinea; lll=allong.
do first to press the sending that to look for the line icon, do first to make lll+ send that menu, edit, object, stretch.
I have almost everything on the keyboard, unless they are set of commands with options (of the macro, to understand).
25 years ago they gave me the nickname "the pianist", for how I drew in acad on version 12 (not 2012... 12!)
exact crystal, but what I asked was to be able to remove that final sending, the sending to activate the command, if you can create a macro that sends and, all under a button, why you can not do the same with the sending, so you can have directly the active line command and you can start immediately to point on the video the starting point? ? ? ?
if you can create a macro that sends and, all under a button, why can not do the same with the sending...? ? ? ?
because even with the button... you send it. is the click on the icon.
if you don't want to press the sending, just put the command icon on the screen. and solve.
