customised formats
  • Thread starter Thread starter Peppe
Peppe
in the table (idw) I created for needs custom formats (e.g. a0x1500 - a0x1700 etc.), seen that the plotter allows me to print these sheets, only that I can not fill with the name of the format the value paper seize.... if I use the standard formats a4 a3 etc.. the value in the table appears to me, while if I use custom formats I appear "user"....
Can you ovviate or do I hold it like this? ?
p.s. inventor 2008 pro
the sheet size data depends on iproperty collection, you should go to idw properties and update the papersize property with the one you defined.
the only thing to do before is go to the installation folder of the ipproperty collection, open the iproperty.ini file and immediately there on put as false the enablepapersize item because otherwise to each save it updates the property with user or with the format set.
the problem is just that it doesn't work anymore with normal ones and you have to update it by hand always... .
I imagined... It's okay as I always did then, considering that "strange" formats I use few I care about my beautiful "user". :biggrin:
