customization drilling table
  • Thread starter Thread starter Stefano-81
Stefano-81
Hi, guys.
I have to put on the table are solid works 2009 sp. 4.1 a plate with a little holes.
I thought I was using a drilling table.
Since the holes are all passing I thought of customizing it and in the description column let him write only the thread dimater (e.g. m12).
I attach 1 image.
Someone please would know how to do it.
Thank you
if you click a cell you see that there are a set of texts that recall the parameters of the holes. Leave alone <hw-threaddesc> and the text simply becomes m12.
I tried to save a model or edit the column properties and then save a new table, but the new table does not keep the settings, I should finish.
so as not to repeat the operation too many times you could put the check "hab same size".
Bye.</hw-threaddesc>
