net
Good afternoon,
after several researches and attempts I couldn't find a solution to customize local labels.
the label should be set in this way: local name (non him avuto problemi)Number inside a circle instead of a rectanglearea of the room inserted in a rectangle with colored filling also the windows, value that I can also insert manually
when I'm in change-text label I can't add any line or circle because I notice "no one of the created elements is visible in the view..." and I can't understand how to solve it because in visibility graphics The label is active.
thanks in advance
thanks in advance
