customized macros and creo 1 and 2
  • Thread starter Thread starter Daniele-san
Daniele-san
Good morning to all,
from wf5.0/creo elemnts to creo 1.0 and/or creo 2.0 what happens to custom macros?
will all work or have to give them back: eek:?
probably this quite dated message has passed into cavalry.
Does anyone of you know how to create and edit macros on creo 2.0?
also those coming from previous versions (creo elements) that end have they done?
I answer myself, but it's for who needs it.
after some search on the web and on youtube I found this simple guide
http://youtu.be/zs1jduax3xu
Nice!
Daniele, do you have experience in crack programming? I'd need some advice to get started!
summary!
I before programming would look at the potential of "standard" creo.
modelcheck:
allows you to check if the models are congruous to the standards of your company;
in addition to this it does so many other things, here you find a summary of the potential:https://support.ptc.com/appserver/c...rt_lang=en&posno=1&q=modelcheck&source=searchfiles trail :
allow you to record a sequence of creo commands and be able to repeat it by reopening the saved trail; you can then customize the trail before launching it so as to change the codes that are loaded and processed, to do this you will have to create an external program.http://www.cad3d.it/forum1/threads/1407-trail-txtHe thinks that sometimes I did it using the "print union" of word, indicating how "variable" instead of the addresses the various codes I wanted to create.
Macro:
command sequence logs that can repeat the actions you have recorded, typing key combinations. also here you can get a high level of automation, similar to trail.
we come to the programming:
protoolkit (c), object toolkit (c++), proweblink (javascript), jlink (java), vb api (visual study, office, etc.) : they are creo programming tools. the first two are paid. When installing I create, if you select them, you will find subfolders in the "common files" with help and examples, you can start there.
Bye!
Good evening, I created some macros I saved in a folder. when I close and restart the program I no longer find macros. How do I call them back?
Bye!
