cut - polygonal youdeling plug
  • Thread starter Thread starter arm
arm
Hello, I've seen no one has mentioned it yet.http://www.clayoo.com/in my opinion a great plug in for the polygonal modeling integrated in rhino. is free and in the development phase therefore still scarce of various tools, but not to be underestimated; for now the sins could be the lack of symmetry and the transparency display of the retrostanti faces of the solid that shapes when selecting a face or edge, which disturbs while trying to shape. valid tool to transform solidclayoo into cloud surface.
will be a valid antagonist of t-splines that, now acquired by autodesk, will not have, in my opinion, further developments for rhino.
enjoyment
exact! even if there are still some bugs, but it seems that the developers have jumped into a thick head, as soon as you signal a problem, they answer you immediately with the solution. We hope you become the alternative... .
free in what sense? Isn't that a trial that you download now? However it is interesting, and in my opinion in a couple of things, those that have developed until now, is superior to tsplines, especially the conversion from sub to nurbs, which does not create dozens of surfaces, is very efficient, and creates the same number of patches.
Among other things, future development aside, autodesk introduced the first novelty, brought the cost to more than 700 euros, I had heard that clayo could cost less than 100.
in fact it is not correct to say free; it is in development phase, therefore by force and free, then perhaps on the first release of the final version will give the legnata:redface:
Unfortunately it expires, it seems to me 90 days.
Basically you register and download. install it and, launched rhino, the first time you charge it asks you the key (equal for all) that you find on their site in a post,http://www.clayoo.com/forum/topics/license-requestthen enter name, email, etc; finally, via web, it makes you activation online. from here lasts 90 days; I don't know what they're gonna do. they update it every 10/15 days.
we hope that they do not do as zebra3d, a cam of which you no longer know anything.. .
I don't think, if it doesn't cost much will replace tspline, which costs a bang, and there are good chances that you will no longer be supported for rhino, and will be integrated into their cad, there is already a preview of tsplines in inventor fusionIt's not a good sign. :
I think so. of cam there are different, while what can do ts/clayoo in rhino is unique.
In addition to the excellent transformation command in nurbs without subdividing into dozens of surfaces, it also seems faster when you go to model moving edges and surfaces, slowness I have always found in ts in smooth mode.
I reported that hiding backfaces when selecting, and responded that this change is being developed in conjunction with mcneel.
I usually pattern in silo, amount in rhino as obj. at subdivision level 0, transform into ts, smooth and retransform into nurbs, but the surfaces are very messed up. The new Clayoo command would be a real bean!
at the beginning I saw that you appointed the command to turn the solid clay into nurbs.. where did you take it??? :or I swear to you, it's a week I'm going ahead looking for it without any results.
