cut sheet metal intersecting structural element
  • Thread starter Thread starter LucaOt
are in the same situation as drake: it doesn't work to me, even trying the facial/plane settings suggested by boulders. if possible massive, could you make the change when you have time and attach the modified file? just to see the parameters you set on the function. thanks to both
I figured I'd cut the pipe. then with short stretch you can not. make a sketch on the face of the sheet or tube, convert entities and size.
My fear is that you could only do as you say! a function to do so would not be bad, especially in case of multiple tubes.
thank you all for helping me and clarifying many doubts.
is one of those situations that must be analyzed a priori. Do you need to make a straight plate like sheet? why not make it as welded and then if it is necessary to convert it into sheet metal?
Good point. Unfortunately, being at first, I still need to know all the facets and possibilities of modeling of the various components. Anyway thank you so much again, the further I go and the more I get hung up on this world!
"to make it as welded" means a simple extrusion, because as structural elements I find only profiles and tubes. .
as structural element you can have any profile you want.
flats, rounds, hexagons, frames, shaped like snowman...
the structural element uses the profiles that are sldlfp files that are created and which consequently are customizable by the user
thanks massive, of that I am aware, I use them regularly, I escaped how to use them for a sheet
how would you use them? the profile in case would be the section of a sheet of sheet of 1500mm for example?
it works almost,the stretching cladding does not round me the edges of the tubeaccorciaestendiImmagine.webp
without property manager of the function as I know what options you put.
you can have rounded edges using the shoulder option between the bodies
to make a dish as welded just make a rectangular .sldflp profile and insert it with the function structural elements on a sketch along as the thickness of the plate
sheet is a word that has an insolidworks weight.
if you do not make folds it makes little sense to use the sheet function only to have in the separate cut the tag with the symbol or because in the workshop they call it so.
use the sheet module when it is necessary to have sheet metal developments or use the appropriate functions, not to pull a straight plate
then you can do a thousand things, even create a folded sheet with structural elements, join them and then convert them into sheet metal.
to analyze I mean this, understand what needs to be achieved not only as geometric model, but also as process so as to choose the best roads
