cut with surface
at this point I should see the file to understand, should do it without any problem.
Is it possible that it does not cut because the surface and the solid are part of two different components?
ahhh li ho zippati
I don't open them. I am using 2019, I have a 2020 installed, but the files are made with 2021 or 2022.
Yes, that's why. You must have the surface inside the same part. to make it do a contextual modification of the component in the axieme, make a surface offet "0" (actually the copi) then cut using the copy present in the part. there are also other methods, this is the most immediate.
Would you, please, want to make me the screen in charge? So I understand how it is done and where it is
Here it is, it is enabled after selecting a component within the axieme.
I still don't understand. . i.e. if I make component modification on the laying does not cut me the surface anyway.
and do not copy me in the solid surface or the offset surface in the laying
And then I don't understand two things:
1.I designed a spline to try to make a cut of supericie between solid and spline belonging to the same component (png attached) and melo inserted outside the laying (at the bottom of the tree)
2.why when I do "open part" to open the single component to me not updated?
to tell us if I do "open part" on the pose give it to me without the two lamature and without rays
Thank you very much
I don't understand what you're wrong, how I wrote you, you should see the model. by model I mean the axieme in which both the surface and the component to dig are contained, unfortunately I do not read your files. What version are you working with?
Thank you very much
1- depends on how you did it, if you used a sketch the spline lies on the plane where it was created
2- the only explanation (it is intuition, not certainties) is that you have done lamature as work together.
I use 2021.. but is it essential that the laying and the cutting piece be part of the same together?
I continue here the discussion as I have to ask a question on the same topic.
to cut a solid compared to a surface it is necessary to make modification component to be cut and to extract all the surfaces, to join and cut. . All right.
this method is great if I have to cut one component according to one surface
but if instead I have to cut more components according to the same surface as I do?
the plastic component (which you see in the attachment) is supported by multiple layings below it.. my idea is to create a single surface that covers all the layings but this surface I would like to have in the tree of the plastic component instead of in one of the poses so as to cut all the layings according to the same surface
now for each of the orange poses I made component modification and I extracted the surfaces of the piece.. and was very long:
if you go to "assieme functions" in the axieme environment there are some functions you can use, including the extrusion size. you have to use it as you do in a part environment, selecting a plan and creating the sketch you need, only then when you go to cut you can select the components involved from the cut and in your case will be all the layings
