piccio__87
Hello everyone.. .
It may seem like an incorrect procedure...(maybe it is also for what I can't do)^_^.
I designed two sheets with flange. . .
so that the inside between the two misuri 41mm
...one 28.5mm and the other 12.5mm...
I applied it over the bracket... I would have to cut the outer surface to the bracket.
I attached the file... first look at us....^_^
ps:uso inventor 2009....
with 2010 I would have known how to do...^_^... still unfortunately I have not....
Thank you....
Thank you....
