Good morning to all, I have a problem of this type : I have a table file in which I have inserted a separate cut for welds , I hide some lines with the hidden/shower icon and everything is fine , but every time I do "save" I reappear the hidden lines .
Yes thank you I have tried but nothing to do ... I have actually verified and does not do it every time except but every time I change the properties (description , code , etc. ) a body
I do, too. in my case they reappear after closing and reopening the table (saving). and also reappeared on the bottom of the separate cut.
How does it work?
you should attach the file because otherwise you must hope that someone can reproduce the same problem in the house in order to analyze it; problematic that can depend on numerous variables: version and service pack, fallacious installation, setting of options, errors in some executive passage.... just to say some. not to mention that playing a problem requires extra time that is not always available.
Did you ever think that you would exclude the parts instead of hiding them?
