cylindrical gear to helical teeth
  • Thread starter Thread starter Davide Costantini
Davide Costantini
Good morning, everyone. I ask a direct question to which you answer with an espresso number in millimeters: if a cylindrical tooth sprocket has z=18 (number of teeth) and mn=5 (normal module), is there a possibility to trace back to the value of the primitive diameter of the pinion?
I will be wrong, but by adopting the classic equations of cylindrical toothed wheels I find myself always having two unknowns in the same equation. Unfortunately I have no other information (such as the angle of inclination of the teeth) as in an old 1998 distinction I found only the number of teeth and the normal module. Of course if the teeth were straight the primitive diameter would be 90 mm, in this case instead?
I hope I have posted the question in the correct forum and put the matter well. Thank you all.
in my very short experience 99% of the time is 20°.... but I would expect an experienced user to help you.
you have to use a caliber specifically to find the corner and then you have to measure the wildabler because it could also be corrected the profile.
This is a component of a separate 1998 I do not have the opportunity to touch it by hand, to make the necessary measures. so without the tilt angle of the teeth you do nothing. thanks to the prompt answers.
problem solved: I managed to trace back to the rack that geared with such pinion. from the catalog of the gudel I found the angle of inclination of the propeller (19° 31' 42") that must be the same as the pinion. from which:
primitive_diameter = mn*z/cosb = 95,367 mm
thanks to all of the answers.
