luigi.paiano
uhm even if I think they are the constraints on the ends that preventing the shifts cause me deformations and so the stresses!! I will ask the teacher!
Yes, otherwise the fluid would not move... there is a difference of die.. is more correctIs the pressure open?
if there is a difference of pressure upstream and downstream, the tube is subject to the difference of pressure.Yes, otherwise the fluid would not move... there is a difference of die.. is more correct
I think it is so...cmq somewhere I had the sizing of pressure ducts...the reasoning that has been done together is right anyway...the tube is more stressed when you stop....we think for example to a dead dog that blocks it:wink:if there is a difference of pressure upstream and downstream, the tube is subject to the difference of pressure.
Clearly if I have a defined range at the entrance, I will have a pscession or better a lesser pressure difference if I have the open end than the stage. But if you say: in the tube there are 4 bars....that is.
hihihihAll right, we've gotten to the chase.
noo thor should reread all the discussion.. we wondered if the pressure was considered as action that puts in traction the tube axially....and in fact the worst case is still fluid and therefore maximum pressure (closed valves or dead dog that blocks the conduct :biggrin....
but look at that you are talking to one who makes the square bouquet every day and if known I never ask simple questions but at the most I look for opinions!!I agree. That's why the part of calculations, Luigi, you have to do it yourself... if you don't bang your head you don't learn!
and anyway the speech of the pressure I am convinced is just in case of steady flow... I remain the doubt you know? since then we have to put in the worst case(valve closing the conduit) then size with pmax... back?
