da dwg a bmp
  • Thread starter Thread starter icione
icione
to the whole ng
I want to send (email) the final result of the work to a customer in bmp format, but the result I got does not like as it is as if it made me see it in very low resolution, you can set somehow the transfer to get a better result? use 2008
Icitation
to the whole ng
Icitation
I get definitely better results using the jpg.pc3 publishtoweb printer of autocad.. .
or export to wmf is a vector format and not affected by the resolution also visualize it with all windows systems with the preview... .
the export bmp,jpg,tif from the export command is bound to the resolution of the screen image that if not erro should be 72 dpi therefore very low.
unless you print in bmp for a problem of "security" or because required by the customer, then it is better a print in pdf.
