tecnico_plast
how can I convert to 3ds format?
I saw that there is okino polytrans, it works well?
the file can also be a simple cylinder :smile:If you attach a pro/e sample file here, we can do a comparative test with various converters. . .
Unfortunately not everyone has pro/e, but if you give us one of your files (even a cylinder is good) we see to make a benchmark...the file can also be a very simple cylinder
right, here is the .prt file:smile:Unfortunately not everyone has pro/e, but if you give us one of your files (even a cylinder is good) we see to make a benchmark...
Thank you.I confess that with some emotion I opened, for the first time in my life, a file of his majesty pro-engineer: look here..
first I converted your cylinder into .stl, then I saved it in .3ds using the following tools:
- One shareware
as your file was little significant, I made up on the net This is what mountain bike, converted with the first, impressive program that works 100% for a month.
- the other of public domain but limited to 2^16 vertices, therefore to be discarded for professional use.
That would be a solution. . .and if you simply carry it out in *.obj from proe?
3ds read the obj format, without switching from 10 export and various shareware.
Actually, the article says that archicad can esportare i files .obj, ma non import them, what explicitly stated for .3ds...
I read it myself, dear fellow countryman :biggrin:Hello colleague siculo
I read this http://www.archiclass.it/main.php?archicad=dialogo_softwareand it seems to me to understand that archicad amounts obj, so the passage from 3d studio does not need.
I can't save the 3d in dxf.have you tried, in pro-e, to save as dxf, that is the standard format of vector interchange?
Not even Vrls?I read it myself, dear fellow countryman :biggrin:
I also did a test by saving an obj with pro/e, but as the friend of the Cadaland says, it doesn't matter:frown:
Not even Vrls.Not even Vrls?
you should ask those of archicad that file recognizes in import.:tongue:
