da solidworks a catia v5
  • Thread starter Thread starter claudio cuozzo
claudio cuozzo
Hello, everyone.
I together with my office colleagues will be required to perform a design through the use of v5 catia, since explicitly requested by the customer.
we all use exquisitely solidworks.
So I wanted to ask: is there a program that can convert solidworks files to catia?
the idea would be to work entirely with solidworks and executive project transform everything into catia files.
xxfast, the passage is contrary, from solidworks to save in openable format from catia. then you should see if the native caty files are included in the extensions that can be saved by solidworks otherwise save them in neutral format. in any case then check how they are opened and managed by catia.
If, for example, the customer wants to be able to work on functions and caws, opening the file, doesn't recognize or confusingly create the risk of working unnecessarily is high.
hi claudio! from solidworks to catia there is no valid connector! if you have to work third-party accounts so much worse...in my opinion you will have to use catia v5
