da solidworks electrical a solidworks
  • Thread starter Thread starter Francesco20
Francesco20
hello to everyone, I'm learning how to use solidworks. I try to explain the problem in a short time. Starting from the schematic created with electrical solidworks, going on cliché processing on solidworks, creating an iec design model, clicking it opens with solidworks. When I click on the cable routing, the following message appears to me: "not all routing lengths have been updated due to errors in routing. manually control routing and update the length." then displays the following errors: "No valid path found: between ewcablex and ewcabley" and "correct cable trefole property: wx undefined cable trefol diameter". I hope you can help me. Thank you in advance.Immagine.webp
you advance that by attaching the file in question; for those who use the eletrical module help you will be much easier
