da sw a solidedge
  • Thread starter Thread starter xxfast
xxfast
not that I intend to draw in sw and open the files with solidedge, but I was wondering if in solidedge there is the possibility to open a part of sw and make him recognize the functions?
If yes, I'd like to know how.
to recognize functions what do you mean?
solid edge can import swx files directly as native files, as well as those inventor, nx, pro/e, catia v4 and v5 though it is a function that you buy apart otherwise you pass through interchange files.
if you mean the feature tree, forget it. no cad does, it is an argument already treated several times. pass through interchange files (step, parasolid) while for tables 2d (dwg/dxf).
apart from this problem now goes on second floor, with synchronous technology in solid edge if you have to manipulate an imported model you do it quietly.
excellent tequila suggestion.
ps. there are products that transmit features from one cad to another.
normally do so between high level cad, where the numbers for the translations are + bodied.. .
are however expensive muy.. .
[A parte questo il problema ora passa in secondo piano, con la tecnologia sincrona in solid edge se devi manipolare un modello importato lo fai tranquillamente.[/QUOTE]I meant as a feature works- recognition functions, present on sw.
What about synchronous technology? :wink:
What about synchronous technology? :wink:[/QUOTE]go to youtube, write synchronous technology to understand everything.
These are dynamic changes on models without history.
in practice to extend a model, instead of looking for the feature, then the quota etc, you can act in 3 ways:
1) take face and pull
2) Put a quota, change and model change
3) sections the solid, quoting the section so created, the model changes
3) sections the solid, quoting the section so created, the model changes[/QUOTE]Okay, thank you all, now I get it.
it would be great to have an interchangeability between the various software for the recognition of functions.
thinks there's trouble bringing an office file to openoffice... and it is at the end of characters with a formatting. . .
think about what it means to transport the features...
if the thing has a value for you, there are several products that try:
- proficiency
- elysium
- theorem
- achelon tranxpress
is (or better) the dream of all designers, especially those who have to work and put hand on models made by others and with different cad. Now the possibility is, that is, with synchronous technology, you can import mathematicians from other cads and change them.
m
there was on the old versions: "automatic feature recognizer", on the new was removed as it was considered supefluous thanks to the advent of sync tech
However application as feature works leave the time they find. I used it once for a job that was born in itself.
at the end the result (sequence of feature) is the interpretation of featureworks and not the modeling that had been developed at the origin.
I think the translators quoted by the_matrix, instead, translate the model as it was conceived on the native cad.
I also heard about it, but when I was mentioned, I turned over. However, it is a question of niche products much less widespread than a cad and inevitably costs rise.
I'm sorry, I have a doubt.
If I get on the solidedge version 21 st and then I go to work in a studio where they use v18, don't I get a problem?
Should the main functions be unchanged? Or not?
However I appreciate much more sw, but purtrippo... .
Just don't practice syncronous technology on v18.
I also think if much better than sw, but unfortunately... .
Who knows, maybe I'll change my mind about it over time. They always give me the new job, as I wait for the answer. :4406:
to practice syncronous technology should I work on imported models, taste?
I am exercising myself from the creation of sketches and new parts.
