data table: column header contains invalid quota name
  • Thread starter Thread starter Cuspide
Cuspide
happy everyone, this is my first discussion on the forum. recently for work/passion I have approached myself independently to solidworks and after a good success achieved by self-taught for basic use of the same, I think it is time to deepen the different themes/problems by drawing on your experience, knowledge and courtesy.
starting pointing in an orderly manner, all stages for the construction of the piece from which I subsequently get errors as the thread title:
  1. I created a triangular plate isoscele (half of a square). < base-flangia
  2. I created a flange from the edge bent to 90°, on a part of the hypotenuse of the base triangle ("accorciando" its sketch and making it a trapeze, with a more hilly base to the hypotenuse of the triangle). < edge-flangia1 >
  3. I created a flange from the edge bent to 90°, on the two caties of the triangle (with a certain distance of play at the top that unites them). < edge-flangia2 >
  4. I beveled two edges of the edge-flangia2 (one on the flange of one catetus and the other on the other). < opening edges
  5. I made two identical extrusion cuts on board-flangia2 (as before). < cut-extrusion1 > and < cut-extrusion2 >
  6. I generated a data table (by blocking the model changes that update the data table) to generate other configurations.
i problemi:
  1. in a sketch once a quota is created, the same is indicated with its primary value (which can be displayed by clicking on the quota) e.g. "d3@schizzo2". for the parameters that define the functions is the same, but I don't understand where or how to quickly view the default name associated with that quota. (the solution I found is to go on function configurations and possibly expanding hidden fields read how much sought) do alternative and/or faster ways exist?
  2. returning to the particular case of the object indicated by points 1:5 , by default per edge-flangia1 to the development depth of the same is associated the quota name d7@bordo-flangia1. the data table loads this parameter, but at the end of the same generates the error column header d7@bordo-flangia1 contains the invalid quota name d7 so it closes, does not update, and in this way I can not get new configurations from data table. How is it possible that you give an error of that type for something named by default?
Thank you in advance for availability
I have not yet found a solution; Has anyone ever seen the same problem? ? ?
Is it a wrong procedure problem or a computer problem?
Hello cuspide, haven't you solved yet? It would help attach the file if you want me to take a look.
cmq from how you explained is not clear construction, what in cold I think and that there is a mistake in step 3 and 4. that then when you go to change some parameters can no longer create these last ones.
