deactivate quick property panel
  • Thread starter Thread starter blubossa
blubossa
to all,
with autocad 2010 I happen to select an object, line, circle....and opens the object property window attunedly. How can I disable? ?
bb
strange phenomenon: Does it happen to you on all existing designs, or even on those created from scratch?
Have you tried to install the last service pack?
you probably mean "fast property" and not "properties".
However, to disable them just click on the penultimate button of the bottom bar (where there are also snaps, grill, etc).
or press ctrl+maiusc+p
tiny clarification: in autocad 2010 is the last button (from left) or the first (from right) :wink:
the selection you make is a double click?or have you set the quick selection?
test the settings of the snaps.
thanks were own the fast properties.... .
