decimals in tolerances
  • Thread starter Thread starter CRAZYMAD
CRAZYMAD
I can't enter the right number of decimals example
I would like to tolerate a plug hole stuck in d7 with toll. n7 -0.004 +0.019
my sw makes me insert the correct data but on the design puts only 2 decimals and writes me d7 n7 -0.00 +0.02
how to fix the number of decimals are 2 hours I try
:36_1_4:
just click on the quota in the table and to the left opens a panel where you choose all the options, including how many figures after the comma
in two hours did you not think to click on the question point that there is on the top right of the property manager?
However read more qui
.... ehmmm :eek::eek:
I had lost myself in a thousand thousand parameters of options I thought it was a config more from menu:( Anyway thanks help we use
so many times the solution is in front of our nose and we cannot find it:
of course + a parameter that you can set even in the options, otherwise if you have to put one hundred tolerates and you have to change them all you want.
see in the online guide this page.
to the left see the tree of the guide and what is sectable in the otions; both general ones that apply for any environment, and those for individual environments and then saving a basic model you carry behind
