default color solid pattern
  • Thread starter Thread starter kadkam
kadkam
Hello
if I create a new .catpart the color of the solid is of that blue;
where do you set the default color?
Hello.
I'm afraid to give you an answer too obvious and therefore bamale. click on the part with the right-click->propriety->graphic_selections the desired color->ok. Is that what you wanted or I was wrong? Hi, stefano.
Hello.
Maybe he wants it for all the new maths.
then you create a catpart and set all the features of the case. to each new filevaiad use the command saves how and use this basic model called in jargo also template. That's what we do.
I mean every time I press the prisma command I always get a blue color solid. Obviously I can change it but in the options I searched but it seems there is no where to set this default color.
@falonef
in the case of your solution where I would set the default "characteristic" color?
the default solid color you can change it only by acting by caia standards (instruments/standard), but to do this you must start from the caia administrator configuration.
for what concerns me I would not change the default colors, because it risks creating inconsistencies between the color of the model and the colors that signal the execution errors of a command.
