default iso standard set
  • Thread starter Thread starter Bondeste
Bondeste
I have a small problem or better a small improvement I would like to do on inventor 2012...practically I would like to make sure that when I go perform a threaded hole on a particular auto I select the iso standard for the type of thread so as to avoid that every time from the drop down menu I have to select the kind of rule I want to use. Is it possible for you? ? I tried to look between the various inventor options but I found nothing.. .
thanks in advance of the help
by inventor I pressed f1, type thread, and I find:
"resorting thread types in hole and thread dialog boxes
You can change the order in which thread types are displayed in the hole and thread dialog boxes, so that the most used thread type is displayed first.
with autodesk inventor closed, open the file thread.xls.
click the thread type tab to change.
in cell d1, change the order number in a value between 1 and n so that it matches the suitable property. it is not necessary that the number be sequential.
save the spreadsheet.
start autodesk inventor and view the changes made. "
