enrico1979
Bye, guys.
I hope it's okay.
I was wondering what I thought was trivial to find in apdl, but instead...
in the case of cross-sections the v12 exceeds the problem of the hinges between the reciprocal components defining a spar 2d element and is fine (although still I do not understand how the prblem can be circumvented in version v14).
in case I had 2 beams, where there was an ink, a zipper (between the two beams that do not bind the same to the ground) and a cart (well different from the case of an ink, a zipper in turn bound to the ground and a cart) as I should behave.
I have tried to define local reference systems, or the coupling\ceqn>coicident node but nn live and I do not find any literature about it
I would be grateful if someone would tell me how to model internal constraints.
thanks early and good Sunday
bye
I hope it's okay.
bye
