teseo
hello to all I am a happy user of a form 2; happy but not until the end,,,,
comparison problems of deformation of the pieces; I'll explain.
I usually use the tough v5 resin with which I mold the most disparate pieces, from micro pieces of a few millimeters to pieces of 10cm x 10cm. after printing the pieces are usually perfect no deformation and mostly reflect the measures(+/-0.2mm), but after a few hours the pieces begin to deform and I have important deformations of some millimeter. I tried to print in different ways on the tilted plane, etc. but the result does not change, does a question arise? Is it just me or is it intrinsic in the car/resin? The pieces are not stable at all, I attach a piece that has taken an important deformation. ...
and its stl file hello and thanks
