delete grid display in the layout
  • Thread starter Thread starter karotto
karotto
Hello.
I can't delete the grid in the layout window, while having it washed on the model, on the layout I can't. I open the window, but when I go out, it doesn't go away. How can I do that?
What the hell does that mean? What window? If you go out, how do you know she didn't leave?
the grid is activated/disabled with f7
it means that every time it opens autocad opens with the activated grid and would like to avoid having to remove it "every time" with "f7".
suggest a setting that allows it to open autocad without the activated grid.
you are able of course!!
Just save yourself a template where the layout window has the grid turned off and always use that as a starting file...or what happens systematically even on uncreated ex-novo files?
You didn't even suggest it, so don't get anyone's eye contact.
who then karotto is the classic user who asks the question, written almost always as crap, receives the answer and abandons the discussion. Since I responded it has been a month and has not been worthy to intervene. so or is not such an important thing, or fails to formulate in a decent way its problem using correct terms or has solved and therefore has no reason to bother responding, thanking, explaining.
Well, I see karotto, I see you, Lupalbez, and I love my misanthropy.
Dear Massivon,
I found the post because I also had the same problem and instead of finding a valid answer I found an answer that with that "heavy" he knew more about reproach than teaching.
Of course, not knowing the answer, which I was also looking for, I searched elsewhere.
It is true that many ask questions in a confused way and do not devote them a few more minutes to express them in a decent Italian, but if anyone knows or believes to know, you do not deserve to understand and give a relevant answer, then you do not do anything but to avoid the forum who would be serious and interested.
I repeat that I did not answer the question because I myself at that time did not know the solution and then, once the question has been resolved, I did not just mind returning to that post to give the solution.
to thank, instead, the intervention of tristan that instead (without being misanthropic) with few words has already given the possible solution giving meaning to the spirit of this forum.
about posts and answers never read... .
I think it is advisable for everyone to change your profile settings,
and then search:
subscription mode to the default discussions:
when you send a new discussion, or answer a discussion, you can choose to automatically add that discussion to the list of submitted discussions, with the option of receiving an email notification of the new answers to that discussion.
and select this option.
to me it was useful to know that tristan had responded... Otherwise his answer would end up in the forgotten and who knows when I would read it.....
Surely a tristan applause, whose competence is commendable, but I did not give answers because I did not understand what was needed to karotto. and I would like to point out that even your, albeit very plausible, remains a conjecture not being, karotto, worthy to respond.
you have no idea how many times to questions with general information I had to ask a list of questions, or possible solutions, to circumscribe the question.
If these lacunous questions are also written worse than bad for me it means that in addition to giving too much misunderstood the help you receive (and in some cases not even the confirmation of solution) you do not respect even those who read by checking if a message two lines sia comprensibile.
lupalzeb, I don't think it's a warning problem; because if you ask a question every now and then go see if you have received an answer, otherwise it's like not to.
I think it's just education and respect. in someone there is in others not. to the first ports equally respect and help them willingly, in the second beginning with the legnatas and then steps beyond.
Mass, don't brash.
I believe that this way of writing is the son of the various whatsapps, twitter, sms and who has more to put it.
stringed messages where 60% of the content you have to imagine or know them a priori, otherwise they will lend themselves to a thousand interpretations.
and the further we go, the worse it will be. I feel it with my son.
I don't think yours is a non-response, rather than that of origin is a no question.
[MENTION=8168]lupalzeb[/MENTION]I would like to point out that he has also put a question, precisely because of the nebulousness of the initial question. and the solution, as you said, is a possible but absolutely neither certain nor relevant. probably for you it is corrected, but perhaps to others with a similar problem (but not identical), it may not work.
But... just for knowledge: did you have the problem solved it?
this just to know, beyond the time lost to write punzecchiamento post and wise advice, if you solved the problem or not (true treadh hazel). This is also the spirit of the forum. know not only by who knows, but also by those who do not know but found a solution.
I agree that often in the forums there are frantic questions and often in an Italian stentato (even I feel a peak for the truth) and not understandable, you want for the rush (we all run) that for lack of respect to the one to whom the question arises. I also think that those who are in the first arms have difficulty in making a detailed explanation of the problem. Maybe karotto will sooner or later return to the forum and tell us if somehow it solved.
as far as I am concerned I solved (though drawing in this case from another site) with the solution proposed by tristan. I opened the default template, turned off the grid and saved with the same name.
However I am pleased that the forum is alive and you can exchange some impressions and/or advice in the break between one grain and the other of every day.
All good work! :-)
