delete or hide present date in a block
  • Thread starter Thread starter Dr.Lube
Dr.Lube
I should do a trivial operation.
in a drawing I have a thousand blocks that define me a point, its number and the quota.
quotapunto.webpI would like to delete for everyone the first item (point number).
Is that possible? How do you do that?
Thank you so much!
dennis
the type of object is a "reference block"
I tried to edit it and here's the result
command: -modrif
select reference:
** impossible to perform modrif on an anonymous block **
Usually quota data are placed on different layers.
It would be enough to freeze the layer on which the point number of quota is placed.
is a single layer, the block is one and contains 3 objects.. I'm afraid it's going to explode.
but with what software has been made I am dwg? Not with autocad, right?
I think so.. But I had problems with those odds that were "autocad proxy entities" objects.
I converted everything with "-aecexporttoautocad" and that is the result. .
Yeah, I'll notice.
the only solution is to explode everything (always you do well).
after with selerapid set as type of object "testom", as "color property", operator "equal to" and finally as "layer" value.
will select all the texts of the quota numbers, which you can delete with one command.
of course it is good that you do this on a file where there are no other data, but only those of quotas.
I don't think so. Do you have the original file? the previous one to aecexporttoautocad?
Yeah, I'll notice.
Thank you so much now I try!
you have what I've left from which the designer provided us. Where do I look?
most probably was made with an application "custom" of autocad; which is not known... but those are not objects that autocad can create independently without the fan of some developer
In addition, each point with its share is different anonymous blocks.
you can try with a lisp, if you have a moment of time.. .
