delete sketch from .drw
  • Thread starter Thread starter cougarz
cougarz
First of all I ask you how you feel better to draw a enjoyment. the last time I had only indicated the surface and the din norm and did not "view" it...so I have to make it graphically visible. I made a sketch with 5 robes vertically and then an axial series in order to fill the whole area. the problem is that it shows me the sketch at the table in all the views, even in the sections!
The subject has already been dealt with.
the enjoyment is achieved first by creating two helical sweeps (a right-handed and the other left-handed) and then an axial series of the same.
the resulting model is quite heavy and a graphic representation of the same is advisable.
I found the thread thank you, remains the doubt about how to delete sketch from some views and not from others, is there solution?
First of all I ask you how you feel better to draw a enjoyment. the last time I had only indicated the superficie and norm din and They didn't see it. . .so I have to make it graphically visible. I made a sketch with 5 robes vertically and then an axial series in order to fill the whole area. the problem is that it shows me the sketch at the table in all the views, even in the sections!
change supplier... or buy a pair of glasses to the operator. . .
In my opinion you first draw it directly in 2d, a 3d model of the genus becomes small,(as it rightly pointed out maxopus), possibly you can then associate the 2d sketch to the view so that if you move or steps etc... you have no problem.. .
Bye!
p-h
Yes, you have to manage layers on individual views.
Hello, Max
I have 2 curves in the model. then I have 2 curves x single views.
I want to delete 1 curve in a single view, but when I click on "hide" inside the view level, I disappear in all views.
Any idea?
Hello, Max
Any idea?
colleagues, have you forgotten me? ...
