blackarrow
What changes in a pair of toothed wheels have a number of teeth first and/or at the same time equal or odd?
I quote and add that such problems had them the mercedes.the odd toothed wheel or better yet first number allows you to have the effort on each tooth at each turn. if it is even will always work the same tooth of the motion with the same tooth of conduct even if it can be a fraction of turn. if one of the two wheels is first surely the other wheel sees different teeth always. they consume more regularly with a higher life.
I am not aware of the specific case, but the fiat on the 1.9 mjet engines mounts belt transmission.there an error of number of teeth in fiat if I don't remember badly they were recalled very many cars fiat stilo for the replacement of the gear or pulley dentata better say the second built in plastic material that broke getting tragic things on the motor i.e. bending of the valves that beat in the head...
Do you want me to make you a "memory" list of absurd things made on even more blasoned cars?http://www.omniauto.it/forum/index.php?showtopic=48390This is one of the many who had the problem that I said, but how do you plan an absurd Tamlemte thing? mha...
to continue the topichttp://www.omniauto.it/forum/index.php?showtopic=48390This is one of the many who had the problem that I said, but how do you plan an absurd Tamlemte thing? mha...
no, it can also have a first and equal number of teeth. what are the first even numbers? and why there can be no other:tongue:?Excuse me if I interfere with this interesting discussion...... so a toothed wheel with first teeth is a wheel that has an odd tooth number?????? both at itis and at university, I have never heard of this:smile:
If he doesn't respond correctly, we send him back to getting middle school! !no, it can also have a first and equal number of teeth. what are the first even numbers? and why there can be no other:tongue:?
