dependence on replaced components
  • Thread starter Thread starter Magno81
Magno81
Good evening proengineers:biggrin:
I briefly summarize my problem.
once a component is replaced in a set, a link between the replaced component and the axieme itself is maintained. visible link in info --> viewer references e selezionando shows dipendenze. This connection is easily dissolved (dx --> disconnection), but manually.
Has anyone had the same problem?
wildfire 4.0 release m120 (also provided with release m050, m060 and m100)
when you replace a component, you must remove the arrow in the folder as noted.
(use proe in German though you should find the commando! )
hi arni, thanks for the answer.
Unfortunately it is not enough as it solves the problem only for axioms created with wf4.0, but not in axioms created with previous versions (we used wf2.0 up to a few months ago).
same problem we have even if we eliminate a component, always in axioms created with versions prior to wf4.0.
