derivation
  • Thread starter Thread starter stilo64
stilo64
I have a set that is parameterized where a parameterized "tubo.ipart" component, where it has two holes, so I can tell how many holes I want both in the first and second with two different steps. i.e. 5 holes with 100mm pitch and 4 holes with 200mm pitch.
then I entered a command that when I only want the first hole with the steps I want automatically the second hole is suppressed.
until here it works, until I use the two steps one for example to 5 holes with 100mm pitch and the other to 2 holes with 200mm pitch in the axieme is updated automatically, taking into account that on each hole I have inserted a valve (in the axieme).
I can have 10 holes with 100mm pitch and 25 holes with 200mm pitch.
in the axieme in the parameter I inserted the tube derivative so that when specific the valve series follows the amount of holes and pitch I gave in the "tubo.ipart".
but when we suppress the second hole of the tube.ipart component, the valves of the second hole remain in sight, I would like them to be suppressed automatically, how can I do?
but what I understand, you could do an iassembly that manages your ipart set, from the iassembly table you can manage the configurations of the individual iparts and the suppression of the "unwanted" details
