scra450
Hello everyone, here I am with a new problmemino:
I should create a mold (right and left negative) of an object.
1) I have bound myself in a new set, "by annexing it", my part in a parallelepipedo.
2) in part I used the "derived component" command by subtracting the object to the parallelepiped.
3) with the command "division" on the xy plane I cut the parallelepiped so as to get the two parts.
the problem lies in the fact that the object is a loft processing between different diameters all on the same axis and therefore the subtraction of the object itself from the parallelepiped with subsequent division exactly in the middle, I should create curved profiles, but strangely I find some square profiles that sincerely do not know from where they came out.
I'll attach some photos to make your idea better.
the object in question I zebrated you to show that the surfaces do not have edges.
thanks in advance and the next
