design a pipe by being able to choose the diameter
  • Thread starter Thread starter luca58
luca58
hello to all are luca58
I want help, I'm looking for a lisp that let me choose from a list the diameter of a pipe, and I can trace it on the drawing.
looking on the internet I found something but asks me the diameter, and then I am forced to see a table to petition it insert.
autocad use 2006 / 2010
thanks for your attention.:finger:
what you are looking for is a program to draw pipe plants, so with curves, t-pieces, climbs, descents etc., or just the possibility to draw of the pipe?
bye
If there is a possibility to draw pipes, curves, pieces to t etc., well come.
Otherwise, I'm fine with just drawing the tube. Just that rightly if I draw the tube it'll take at least a few curves.
would be practical (if there is a lisp) a lisp that allows to draw the tube with its curve. I attach an example
Thank you for your intervention
I'm getting rid of my program just the part of the software you need is very complicated.
If you don't find anything around and your need is work, contact me by email.
bye
On the net, I found what I was just looking for is in vba while I wanted it in lisp.
I attach the file I found.
I think it can serve:
greetings to all of you luca58
somehow solved???? The dvb you attached doesn't work.
Do you keep drawing them by hand then? ? ?
I'm sorry to contradict you, but I downloaded the dvb that I had uploaded, and it works to me, I'll give you a try.
I used 2006.
greetings luca58:finger:
