smoking
Good morning to all, I would like to ask you a question about the use of design assistant. the operation I would like to perform is, I imagine, among the most trivial: I need to detect in which and how many assemblies a particular is used. from resource management, dx key on the particular, design assistant, management, find files after selecting the *.iam icon. so far everything ok; unfortunately the result is absolutely unreliable as it never returns to me all the assemblies in which the particular is actually used or even returns me an absurd "0 file(s) found" or often gives me different results if I repeat the command. Is there someone who has any idea or knows how to indicate a valid method but above all reliable to identify the "fathers" of a particular one? Thank you very much.
