design home o-ring
  • Thread starter Thread starter stepbike41
stepbike41
Hello, would you tell me where I can get a good catalog for the design of the premises for o-ring?
the site fluorgum.it seems to be done very well and there are many technical info but I can not access the tables for details.
Thank you very much
Also hunter but better look at the angle+pfister since they are world leaders regarding the or. alternatively also parker
on the site a+p I go every day, but I found only the size of the or, for the sites I think there is nothing, but maybe I didn't look good enough.
Look at this link which is the site of my gasket supplier. find the catalogs of most seals with commercial profile and in particular if you click on products and then the square in the center with written "or" ring opens you a comfortable brochure in pdf where you find all sizes of or and relative locations!
giotama
I recommend you more than anything else the simrit. they are the real world leaders of seals. also requesting the paper catalogue you will find all the tables with the dimensions necessary for the realization of the gorges.
on the paper catalogues of angst-pfister there are some dimensions of the gorges for o-ring, but there are some quotas such as the measures of the bevels or the fittings of the gorges, which are important enough to avoid damages during assembly.
Since we're here.
seal with or tree/hole, static seal.
that game give to mast/hole coupling.
on the various manuals are reported the quotas of the gorges but I never found a quota between the two diameters of the type:
d tree = 100
d hole = d abero + 2s = 100.2
with s = radial game equal to 01 mm?
what game do you give to the various pairs?
I attach a pattern
thor105 in the specific catalog only of the angs+pfister there are the gorges and bevels that you ask.te I say it because I have the catalog under hand.
Now I try to download it.
If I can't find it, I'll ask
say I have a series of or on diameters from 80 to 115 mm nominal
Thank you for reporting.
I confirm to the tolerance on the shaft/hole diameter of h8/f7 (recommended).
we also talk about radial tolerance according to pressure.
radial play is the function of fluid pressure or increased pressure and radial play increases the danger of extrusion of the oring ring.
also the section of the rope and the hardness of the mix influence the sensitivity to extrusion.
