design in 2d without the 3d model
  • Thread starter Thread starter Lucky74
Lucky74
hi, I press that I am a neophyte in the use of inventor and use it especially regarding the creation of plug-ins and customizations. But today I had a bad surprise. Is it possible that he can't make a 2d drawing if not connected to a file3d? in other cad (e.g. thinkdesign) if I want to make a 2d design "unconnected" by a 3d I can do it quietly but with inventor (I use professional 2008) I did not succeed ... I am unable or really so?
using the "scratch" command you are able to draw and quota in 2d, careful though it is not practical at all.
in the pack of inventor there is also autocad that serves to make the 2d.
using inventor to make 2d is like going to plough the field with a countach only because it is a lamborghini like tractors.
I thought I said the same thing... maybe less colorful!
Yeah, maybe lucky74 has a reason to draw 2d on inventor rather than on autocad, you can tell us. .
mah, now that with 2010 of autocad the 2d is parametric... I think it doesn't make sense.
Sometimes it happens, maybe put the car on the table and around the sketches what you want will be the protection fence.
As long as you stay inside the associative environment, the table remains connected to the model, if you go on autocad....
also... .
in inventor just save in dwg inventor, open in autocad and make the fences (in this case) and what is autocad remains of autocad and what is of inventor remains of inventor and associative and openable in both environments.
